How to disable SSID broadcast on Hub One Router
- My Router
- How to disable SSID broadcast on Hub One Router
03-07-2020 9:55 AM
I think someone is piggy-backing our WiFi. I would like to turn off SSID broadcast but I cannot find how to switch it off. Plusnet suggests turning broadcast off but its details on how to turn off only takes you so far but cannot see once logged in to router how to stop SSID being broadcast.
Re: How to disable SSID broadcast on Hub One Router
03-07-2020 10:07 AM
Have you considered changing the WiFi password ?
03-07-2020 12:39 PM
03-07-2020 2:59 PM
Thanks Champnet - I thought this may be a way to prevent other users without having to update any device connected to the router - I am working in the dark with this tech so looking for any easy way to sort issue.
03-07-2020 3:01 PM
Thanks Baldrick 1 - I get what you and Champnet are saying. Thanks again
03-07-2020 3:24 PM
@BobPlus Fair enough changing your password but if someone is leeching your connection then they cracked it once already to get in and will no doubt do it again. You need to make your new password as long as possible just to make it as hard as possible for them.
You might also want to consider contacting the authorities about this as it is a criminal offence!
03-07-2020 5:49 PM
But the OP said he thinks someone is piggy-backing his WiFi.
There may be a benign explanation.
ADSL2+ Billion 8800NL
03-07-2020 6:11 PM - edited 03-07-2020 6:16 PM
Have you thought of running a IP scanner on you network, this will list all devices connected to your LAN by IP address.
Advanced IP scanner for Windows 10, I also used a Android app called Net Analyzer. Both identify the manufacturer of the Network Interface
Dan
04-07-2020 8:53 AM
Thanks Hero
04-07-2020 8:54 AM
Thanks Dan - I will look at that possibility. Regards
04-07-2020 9:14 AM
@198kHz Which is why I used the words might and consider.
- My Router
