How to connect a plusnet router instead of the hyperoptic one.
Sylus
Hello guys,,
Http://imgur.com/5hur3oB
I have this plusnet router and want to use it instead of the default one which is constantly dropping out and giving poor signal. But I’m a technology idiot so was wondering if someone could explain how to do it?Huh
3 REPLIES 3
198kHz
Fixes: 41
Re: How to connect a plusnet router instead of the hyperoptic one.
@Sylus Welcome to the forum.  🙂
Guides are available if it's one of these -
https://www.plus.net/help/broadband/router-user-guides/
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
RealAleMadrid
Aspiring Hero
Fixes: 59
@Sylus  Presumably you have broadband provided by Hyperoptic, Not too sure if a Plusnet router is going to work. Do you know your username and password to authenticate the connection? Also you will need to connect using the WAN socket as I believe your broadband is supplied by an ethernet connection to the router. Best of luck.😀
bill888
Champion
Fixes: 38
Plusnet routers are locked to BT and Plusnet.  Hub One cannot replace existing Hyperoptic hub.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
