How to add a mesh wireless router?
- My Router
- How to add a mesh wireless router?
03-05-2021 4:07 PM
I have invested in a Mercusys AC1200 Dual Band Wireless Router AC12 to extend the internet coverage in my house. When connected to the WAN port on my PlusNet Hub One router
Connection Type Static IP
Dynamic IP
PPPoE Is this the correct option?
L2TP
PPTP
Username My PlusNet user name
Password My PlusNet password
Server IP/Domain Name What should I enter here?
Then for the PPPoE option:-
The connection should then self-populate. But it doesn’t.
Internet IP 0.0.0.0
Internet DNS 0.0.0.0
Options then are:-
Dynamic IP or Static IP Is Static IP the best option?
IP Address 0.0.0.0
Subnet Mask 0.0.0.0
Gateway 0.0.0.0
DNS Server 0.0.0.0
There is an ‘advanced option’ to populate, manually, these values but I am at a loss as to where to find them and which values to use.
Can anyone help, please.
Re: How to add a mesh wireless router?
03-05-2021 4:10 PM
Moderators Note
This topic has been moved from Fibre to My Router
03-05-2021 4:14 PM
What you’re trying to do won’t work. The hub one doesn’t support modem only mode which is what you’d need to have.
Options are either
- Turn off the routing functions of the mesh.
- buy a separate modem.
Most of the mesh systems are designed with markets like the USA in mind where a ISP just provides a modem and you can connect any router to it.
03-05-2021 4:21 PM
@Ray773 Welcome to the forum.
I'm afraid that this will not work. The Hub One cannot be used as a bridge modem. You have two choices.
1. Configure your Mesh system as an Access Point and connect it to a LAN socket, not the WAN one.
2. Replace the Hub One with a stand alone Modem. Either buy a new modem or a cheap modem/router that can be configured as a bridge modem. Alternatively go onto an auction site and buy a Model 3B HG 612. With this option you will need to input your Plusnet credentials into the Mesh unit. The settings are here https://www.plus.net/help/broadband/broadband-connection-settings/
03-05-2021 4:22 PM
The WAN port on the Hub1 is an input port, not output as you are trying.
The WAN port of your router needs to connect to a LAN port on the Hub1.
You should not need username or password, the Hub 1 will handle that, and you should use the Access Point settings on your router.
- My Router
