How long to wait before swapping router?
FIXEDTopic Options
- My Router
- Re: How long to wait before swapping router?
20-07-2021 7:36 PM
Hi. ISPs always say speeds will vary for the first 10 days while they stabilise the connection. Do I have to wait until the new 10 day settling period finishes before swapping to a BT router or can I do it straight away? I've set up the Plusnet router.
Fixed! Go to the fix.
Message 1 of 2
(391 Views)
1 REPLY 1
20-07-2021 8:59 PM
@Mindfulmatt If you are on FTTC then there is no 10 day training period, you can change the router whenever you like. I think ISPs perpetuate this fallacy so they don't need to do anything for 10 days if there is a problem after activation.☹️
- My Router
