How do I disable 5g
Seadog-47
How do I disable 5g
Can anyone tell me how to disable the 5g connection? I thought I had, went to the web page and disabled wireless and now I find that 5g is back and I can't see how to disconnect it.
Cheers
3 REPLIES 3
DS
Champion
Fixes: 22
Re: How do I disable 5g
Welcome to the forums @Seadog-47
But did you click apply?
If not, click the following http://192.168.1.254/index.cgi?active_page=9105
On the wireless network enable, instead of the default of yes, select no and click apply
Seadog-47
Smiley Yes, but I missed the button for 5g....Duhhhh. Fixed now. we're running wired.
DS
Champion
Fixes: 22
Glad to hear you sorted it out @Seadog-47 Smiley
