How do I connect Xbox 360 live to Hub one?
Tim70
HI,
I can't get past problems with IP address. Says I have to check DHCT enabled so phoned plusnet and they said that all their routers are. Have network adaptor. Not really sure what to do next as not very savvy with this sort of thing. Maybe easier to buy amazon firestick although pains me that this does not connect automatically. Any help would be much appreciated.
Tim
1 REPLY 1
bill888
Champion
Fixes: 36
Re: How do I connect Xbox 360 live to Hub one?
Is your Xbox 360 connected via ethernet cable, or over wireless ?
The Hub One is a rebadged Home Hub 5 Type A.  This thread may be helpful:
http://forums.xbox.com/xbox_support/xbox_360_support/f/9/t/1793627.aspx
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
