How do I change the usename of my router from 'admin' ?
John_GC
Hi for security reason I want to change the username of my router, how do I do this ?
5 REPLIES 5
pjmarsh
Fixes: 20
Re: How do I change the usename of my router from 'admin' ?
For anyone to be able to start to answer that, they'll first need to know what router you have.
John_GC
I have a Plusnet Hub One.
Mustrum
Fixes: 77
You can't change the username.
You can however change the WiFi SSID and the password you use to connect to it.
John_GC
OK, thanks. I have already changed the password and the wireless SSID and password.
EmilyD
Fixes: 117
Hi @John_GC,
Thank you for getting in touch. The Hub One's username can't be changed to anything other than "admin", I'm afraid.
It's possible to change the router's admin password, wireless password and the SSID. You can find more information on the router settings here.
 Emily D
