How do I access a USB HDD plugged into my Hub One router from the internet?
- My Router
- How do I access a USB HDD plugged into my Hub One ...
14-07-2019 11:42 AM
I have a HDD plugged into the USB port of my Plus One router.
I can access the HDD from my Windows 10 laptop locally using \\pnhub1\usb1\foldername
My question is; is it possible to access the HDD from the internet, i.e. access it externally? If so, then how's it done?
Thanks...
Message 1 of 2
(246 Views)
1 REPLY 1
Re: How do I access a USB HDD plugged into my Hub One router from the internet?
14-07-2019 12:56 PM
It can't be accessed from the Internet.
Message 2 of 2
(232 Views)
- My Router
