Horrific Wifi Speeds - adding in TP Link AX72
mariavmcdonald
Re: Horrific Wifi Speeds - adding in TP Link AX72
OMG! IM CONNECTED!!!!!
Thankyou so much Dan! I haven't looked at speed etc but I'm connected thats all that matters right now 🤣
mariavmcdonald
Holy [-Censored-]. Getting 395 download speeds now, was barely getting 120 before.
Dan.. you are a legend!
So pleased everything has worked and you have seen a positive improvement. 🙂
mariavmcdonald
Fingers crossed it stays that way!
Now need to reconnect everything, so will see then!
Again, thankyou incredibly!
mystreet1
Seasoned Pro
Fixes: 7
@mariavmcdonald, when you say now to reconnect everything. If it is wireless devices an easy way to do it is to access the control panel and rebate the WiFi network and password to your existing one. All devices should seamless connect within having to reconnect each device. Best to fo it from a wired device.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
mariavmcdonald
Thanks Mystreet.
I went through the ballache and did it all manually yesterday in the end 🤣
But will definitely remember for next time!
