Home hub 6 swap - is mine correct?
- My Router
- Home hub 6 swap - is mine correct?
13-10-2020 7:40 PM - edited 13-10-2020 7:41 PM
I have just purchased this for £5 I was wondering if it is correct and will work as a replacement for the Plusnet router.
It has super fast written on it and has 3 ports in yellow and the last one states wan with a usb
Will this work with my home broadband and easy enough to swap across all advice would be good. I did read the forum but confused on the versions. Thanks.
Message 1 of 4
(473 Views)
3 REPLIES 3
Re: Home hub 6 swap - is mine correct?
13-10-2020 7:50 PM
@Trvhrt Welcome to the forum.
Yes, you just lose the use of the LAN port labelled WAN. See. https://community.plus.net/t5/My-Router/Using-a-FTTP-Smarthub-6-on-a-Plusnet-FTTC-Service/m-p/165176...
Message 2 of 4
(462 Views)
13-10-2020 7:51 PM
Thank you can’t wait for it to arrive. Hopefully fixes the drop outs and slow connections with more devices connected. Got it super cheap to!
Thanks I’ll be sure to follow you’re guide
Message 3 of 4
(460 Views)
16-10-2020 5:36 PM
Hey it arrived today followed your simple instructions took about 5 mins all running smooth and working well.
Thanks again.
Thanks again.
Message 4 of 4
(368 Views)
- My Router
