I've had my Home Hub One router for ages with no issues, then the past few weeks it started to reboot itself, then started rebooting itself multiple times a day.
I thought this could have been related to the 5GHz issues people have been reporting, so I disabled the 5GHz band through the admin page.
This seamed to help for a day, but then it froze, didn't reboot itself this time so I rebooted it manually using the switch on the back, however the lights went out and never turned back on again. Ah Panic!
Checked the charger with a multi meter and switch at the back, both working and as expected.
I've ended up going back to the old Home Hub Zero + Open reach router we had from years gone by however we've lost the high speed 5GHz band.
Is there anyway to get a replacement Home Hub One for the faulty one?
