Home Hub One - Cannot Port Forward to Multiple Devices
Malachor
Hello,
I have a port-forward rule to forward certain ports for a game launcher to my main PC.  This works fine.
I now have an additional machine that I need the SAME rule applied to; but it won't let me do it.  Why not?
I don't want to remove the application, nor do I want to select the same device.  I want to use the same rule for another device.  All I need is to use my exisiting port-forward rule to 2 devices, not 1.  How do I do this?
Note: I've tried creating a new game/application with the same port mappings but that doesn't work either.
Many thanks
Mal.
5 REPLIES 5
Fixes: 315
Re: Home Hub One - Cannot Port Forward to Multiple Devices
Think about it. If a packet arrives to your external address and the port being forwarded , how would your router know which of the two internal IP addresses it should be forwarded to?
Malachor
Presumably becuase of the rules telling it which way to go - I'm not sure.  I'm guessing it can only go to one place, not one to many.
If it's not possible i'll accept it as a limitation; otherwise if it is possible I would appreciate a workaround Smiley
Thanks for responding
Mal
Fixes: 315
Correct, that's why the Hub One ( and all other routers AFAIK ) will prevent you from setting up more than one portforward for the same port.
Are you sure you need to portforward at all ?
Malachor
Aye it's the only thing that prevents launcher download errors when running FFXIV. I guess I'll have to switch between the two devices as and when it's needed. Cheers for responding. All the best.
Mal.
PaulScott
You could technically bypass DHCP and manually assign the two devices's the same IP in the network and that would work - so long as they aren't switched on at the same time. You'll end up with an IP conflict if they're on at the same time.
