Home Hub 6 stopped orange light
davebetts
I've been using the home hub 6 fine for the past year but all of a sudden on Saturday it went off and I couldn't connect the light flashes purple then went orange.
I've gone back to using the Plusnet router although the range isn't very good compared to the home hub
Tried everything eventually I reset it and set it up again with my username and password it was working fine for half the day when the internet started to lag so I switched the router on/off then we lost connection the purple light came on again then orange.
The router doesn't show up on WiFi and I can only access it via ethernet any ideas?
The errors saying NC1-3
5 REPLIES 5
LifeonMars
Seasoned Pro
Fixes: 12
Re: Home Hub 6 stopped orange light
see message 208 here and try a complete reset or you may just be unlucky and the HH6 has gone faulty
https://community.plus.net/t5/ADSL-Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1674550#M333975
davebetts
I've done a complete reset although I left the cable plugged into the socket
Fixes: 413
It sound to me that it's died.
davebetts
Yep I think it's dead. Back to using the rubbish Plusnet router ordered a WiFi booster which should help
Fixes: 413
@davebetts
It would be cheaper to go onto EBay and get another Smarthub 6.
