Home Hub 6 stopped orange light
- My Router
- Home Hub 6 stopped orange light
26-09-2019 9:56 PM - edited 26-09-2019 9:57 PM
I've gone back to using the Plusnet router although the range isn't very good compared to the home hub
Tried everything eventually I reset it and set it up again with my username and password it was working fine for half the day when the internet started to lag so I switched the router on/off then we lost connection the purple light came on again then orange.
The router doesn't show up on WiFi and I can only access it via ethernet any ideas?
The errors saying NC1-3
Re: Home Hub 6 stopped orange light
26-09-2019 10:10 PM
see message 208 here and try a complete reset or you may just be unlucky and the HH6 has gone faulty
https://community.plus.net/t5/ADSL-Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1674550#M333975
26-09-2019 10:44 PM
28-09-2019 1:25 PM
It sound to me that it's died.
28-09-2019 1:32 PM
28-09-2019 2:58 PM
It would be cheaper to go onto EBay and get another Smarthub 6.
- My Router
