Help needed Plus Net router/BT Whole home discs
joshfishkins
Hi all
I have the latest PlusNet router plus the BT WholeHome discs to boost wifi performance around the house. At first all was fine, but recently I've noticed drop outs when moving around the house - wifi signal will show full or nearly full but things like Facebook/gmail won't load. Also, if I do a speedtest on the network I get around 6MB download. If I enable the Guest mode on the discs, I get about 29MB. Any ideas? Is there something wrong with my router? I've tried resetting it.
3 REPLIES 3
Fixes: 1,480
Re: Help needed Plus Net router/BT Whole home discs
Moderators Note
This topic has been moved from Fibre to My Router
bobpullen
Fixes: 314
How have you configured things? Have you disabled the wi-fi on the Hub One?
joshfishkins
A friend who does this for a loving set it all up. WiFi is disabled on router yes.
