Help my kindle fire will not connect wirelessly no more
- My Router
- Re: Help my kindle fire will not connect wirelessl...
05-08-2016 8:54 PM
Re: Help my kindle fire will not connect wirelessly no more
05-08-2016 9:31 PM
Hi @Kerrikk
Welcome to the forums.
The Hub One is really a rebadged BT Home Hub 5 Type A so any issues are better addressed by googling for them using the Home Hub 5 in the search , not the Plusnet Hub One.
This is from the Amazon help https://www.amazon.co.uk/gp/help/customer/forums/kindleqna/?forumID=Fx3RLE6WY0PI1B4&cdThread=TxXQK2R... which may help you.
06-08-2016 10:14 AM
Has your WiFi password changed recently and hasn't been updated on the Kindle? Even if not I found pressing on my router in the WiFi list on the Kindle and selecting 'forget', letting it get re-detected and entering the WiFi password afresh often did the trick for me.
08-08-2016 12:34 PM
Hi Kerrikk,
What you need to do is perform a factory reset on your router as the password in your router is not matching which is causing the authentication issues.
To find out how to perform this reset please go through this link https://www.plus.net/help/broadband/router-user-guides/ select the hub one router and then scroll down to the last drop down which says how to reset my router and this will guide you through the process.
- My Router
