Help me if can please!
Manucortix
Hi every one, this is my first post and i need to say, English is not my main language sorry if i write something wrong.
I think someone is taking the [-Censored-] in my router limiting my downloads and uploads and kicking me out of my internet connection. I'm no good at all with nets and that, if someone know how can i close the door....
The worst of all is: is so useless to reset (no restart)  the router because it auto-configure it self (you ll see it at log)
I leave here a log of my router just after reset it...
Thanks for all!
6 REPLIES 6
Oldjim
Fixes: 63
Re: Help me if can please!
Can you explain in a bit more detail what is happening as the detail from the log doesn't seem to show a problem although If you are seeing regular connection drops can you check the phone line by dialling 17070 option 2 quiet line test and advise if there is any noise
markhawkin
Fixes: 11
@Manucortix
A few more facts would be most helpful.
Are you on "fibre" broadband or ADSL ?
What speeds have you previously had ?
What speed do you expect ?
Are you connected in the master socket with no other cable connected ?
Browni
Aspiring Hero
Fixes: 59
Attenuation down: 29.5 dB, Attenuation up: 29.3 dB indicates a problem, whether internal or external remains to be seen.
Try using the test socket first of all and post back with the router stats.
@markhawkin the xdsl linestate indicates ADSL.
Manucortix
Hi thanks for answer,
Sorry for the short explanation.
I have ADSL 20mb, The computer is connected to the router by Ethernet and i just wireless to small devices, the point is i had a lot of strange problems, strange drops and strange restarts , every day is a different speed, variate a lot, and what is strange to me is that limit was set after i restart or after hold the very small botton (like in the log uploaded) and very strange settings in the router log i realy dont understand at all.
Browni; the test socked i googled it and its a program or what explain me  a little more please
Thanks all!
PeterLoftus
Fixes: 5
To find the test socket, see if you can unscrew the two screws on the bottom of your terminal box. The test socket is behind Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Oldjim
Fixes: 63
this may help https://www.youtube.com/watch?v=9IG8rcadbj0&list=TLtxdw4fz_1SU
@Browni well spotted - I totally missed that one Embarrassed
