Has Smart Setup been removed on BT Business Smart Hub?
- My Router
- Has Smart Setup been removed on BT Business Smart ...
25-07-2020 12:27 PM
So I've recently got hold of one of the 088315 hubs, to replace my Plusnet hub and setup was really straight forward, using the methods detailed from Baldrick1 in this thread. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673
However, for me it could have been even simpler, had I not been stumped trying to turn off the smart setup option mentioned in Baldrick1's instructions.
As the hub was new I decided not to reset the router, but when I came to turn off the smart setup it wasn't available. I did a few searches online and when nothing came to light I went ahead and reset the router, just in case, but the smart setup option was still not available. In its place was a tile for the public Wifi.
In the end I gave up, went to advanced settings, put in my Plusnet details and after plugging in my cable, connected without a problem.
I've since connected a few devices to the hub and don't get any annoying questions/stages that people suggest is the reason for turning of the smart setup option.
Out of interest does anyone know if this option was removed from hubs with a firmware update?
Re: Has Smart Setup been removed on BT Business Smart Hub?
25-07-2020 12:51 PM
I don't know when it was removed, probably at the same time that the BT WiFi options were improved. Anyway it is still there as far as I am aware on residential hub versions.
As you rightly say, it's not there now on the Business versions and can be ignored.
The reason I recommend a factory reset is in case a previous users had changed default settings such as Port Forwarding.
25-07-2020 1:20 PM
Oh good it's not just mine then!
A reset is always best for a used device. Mine was still new in a sealed box which is why I initially omitted that step.
Thanks for your help...I've now got much better coverage with good speed throughout the house and have been able to remove a second hub that I was using as an access point. Certainly worth the £20 investment.
- My Router
