HG612 and Own Router
dazzlerellis
I've been doing some reading and ordered a HG612 which I will flash and unlock with howlingwolfs fw.
I've also ordered a tplink router which I plan to flash with dd-wrt
In layman terms is this correct.
1. Unlock HG612
2. Enter Plusnets connection details into router
3. Good to go?
Or any other useful tweaks to get the best out of this combo
Tags (3)
2 REPLIES 2
Fixes: 419
Re: HG612 and Own Router
Yes. The router settings are here https://www.plus.net/help/broadband/broadband-connection-settings/
You should not need to touch the HG612 settings. However if it was me I would start by seeing if you can get a connection and the combo works before flashing the HG612 firmware. This way you make sure it's working before you start. Alternatively if you flash it first and it doesn't work you won't know if the HG612 was duff before you started or the flashing has gone wrong.
dazzlerellis
Thanks good shout
