Guest Network
Fixes: 52
Guest Network
Is it possible to create a guest network on a BT HH5
2 REPLIES 2
Mustrum
Fixes: 77
Re: Guest Network
Simple answer, no, well not on the standard software.
Fixes: 52
Re: Guest Network
Thanks - there was a possibility of getting a unused one for free. Only reason to consider it was if a guest network was available.
