Found this in event viewer after noticing slow speed
- My Router
- Re: Found this in event viewer after noticing slow...
19-02-2018 1:52 PM
11:19:28, 19 Feb. | (88148.010000) NTP synchronization success! |
11:10:35, 19 Feb. | (87615.440000) CWMP: session completed successfully |
11:10:35, 19 Feb. | (87615.280000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
11:10:27, 19 Feb. | (87607.480000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
11:10:27, 19 Feb. | (87607.470000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
11:10:25, 19 Feb. | (87605.550000) WAN operating mode is VDSL |
11:10:25, 19 Feb. | (87605.550000) Last WAN operating mode was VDSL |
11:10:24, 19 Feb. | (87604.210000) PPP IPCP Receive Configuration ACK |
11:10:24, 19 Feb. | (87604.210000) PPP IPCP Send Configuration Request |
11:10:24, 19 Feb. | (87604.200000) PPP IPCP Receive Configuration NAK |
11:10:24, 19 Feb. | (87604.190000) PPP IPCP Send Configuration ACK |
11:10:24, 19 Feb. | (87604.190000) PPP IPCP Receive Configuration Request |
11:10:24, 19 Feb. | (87604.190000) PPP IPCP Send Configuration Request |
11:10:23, 19 Feb. | (87603.060000) PPPoE is up - Down Rate=54932Kbps, Up Rate=14447Kbps; SNR Margin Down=8.1dB, Up=6.0dB |
11:10:23, 19 Feb. | (87603.050000) CHAP authentication successful |
11:10:23, 19 Feb. | (87602.990000) CHAP Receive Challenge |
11:10:23, 19 Feb. | (87602.990000) Starting CHAP authentication with peer |
11:10:23, 19 Feb. | (87602.990000) PPP LCP Receive Configuration ACK |
11:10:23, 19 Feb. | (87602.980000) PPP LCP Send Configuration Request |
11:10:23, 19 Feb. | (87602.980000) PPP LCP Receive Configuration Reject |
11:10:23, 19 Feb. | (87602.980000) PPP LCP Send Configuration ACK |
11:10:23, 19 Feb. | (87602.970000) PPP LCP Receive Configuration Request |
11:10:23, 19 Feb. | (87602.970000) PPP LCP Send Configuration Request |
11:09:38, 19 Feb. | (87558.240000) CWMP: session closed due to error: Could not resolve host |
11:09:36, 19 Feb. | (87556.030000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
11:09:36, 19 Feb. | (87556.020000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
11:09:33, 19 Feb. | (87553.110000) PTM over DSL is up |
11:09:04, 19 Feb. | (87524.040000) CWMP: session closed due to error: Could not resolve host |
11:09:04, 19 Feb. | (87524.000000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
11:09:04, 19 Feb. | (87523.990000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
11:09:03, 19 Feb. | (87523.570000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
11:09:02, 19 Feb. | (87521.730000) PTM over DSL is down after 1457 minutes uptime |
11:09:02, 19 Feb. | (87521.710000) PPPoE is down after 1456 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
11:08:59, 19 Feb. | (87518.960000) PPP LCP Send Termination Request [User request |
Message 1 of 4
(725 Views)
3 REPLIES 3
Re: Found this in event viewer after noticing slow speed
21-02-2018 12:48 PM
Message 2 of 4
(639 Views)
21-02-2018 4:35 PM
Line tests always are okay. It was the buffering on BBC iplayer that made me look at the log and the slow download speeds I was experiencing. I have used the erratic BT speedtest and my download speed has, according to them been varied between 6.75mbps and 30.5mbps. My line is set at 52mbps so that is why I looked.
Message 3 of 4
(624 Views)
21-02-2018 4:43 PM
@adamwalker sorry forgot to mention cable connection not wifi.
Message 4 of 4
(619 Views)
- My Router
