Firmware version
- My Router
- Firmware version
Firmware version
26-02-2019 3:19 PM
Hi how can I check which firmware version I have as I'm not sure if it needs updating.
Message 1 of 2
(279 Views)
1 REPLY 1
Re: Firmware version
26-02-2019 3:33 PM
If it's a PN Hub One, then logging in will give you your current firmware version at the bottom of any page.
Some users have reported 4.7.5.1.83.8.237.2.2
Most would be on 4.7.5.1.83.8.259 (though this introduced a wifi issue for certain devices
And 4.7.5.1.83.8.263 is a manual process atm, probably moving to auto anytime soon(ish)
If you're on the middle, then PN can push it to you if you report wifi issues.
Message 2 of 2
(273 Views)
