Firmware update
zealing
Firmware update
Hi
My router is showing an old version of software - Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 19/07/17
Please could you push the latest one out to me?
Many thanks
4 REPLIES 4
bill888
Champion
Fixes: 38
Re: Firmware update
fwiw, failing 5 GHz wifi reported with latest firmware since March 2019 by many customers
https://community.plus.net/t5/My-Router/Hub-One-losing-internet-connection-on-5Ghz-WiFi-only/td-p/16...
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Fixes: 1,596
Re: Firmware update
Thanks for getting in touch @zealing
I've re-added your router onto the hardware management platform, if you can factory reset the router by pushing a paperclip into the reset pinhole at the back for 20 seconds you should see your router update after 48 hours.
zealing
Re: Firmware update
@Gandalf Hi, I did the reset nearly a week ago and the router is still showing Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 19/07/17
Any ideas?
Fixes: 1,596
Re: Firmware update
Thanks for getting back to us @zealing
To make sure that we've got the right details for your router, could you PM me the serial number and the first 6 letters/numbers of the MAC from the label on the bottom of the router?
