Firmware update time - can it be changed?
mattio
Hi all. Is it possible to change the time firmware updates are done? The current 2am time interrupts other things in my house and I'd prefer to set it as a daytime update if possible. Thanks
5 REPLIES 5
Re: Firmware update time - can it be changed?
@mattio welcome to the community
Firmware updates do not happen that often
Update
Firmware version:	v0.10.00.04201-PN
Frimware updated:	30-Jun-2023
Update
Firmware version:	v0.08.00.08297-PN
Firmware updated:	31-Oct-2022
Update
Firmware version:	v0.06.00.12134-PN
Firmware updated:	16-May-2022
Original
Firmware version:	v0.05.03.07154-PN
Firmware updated:	Unknown
This is the history for my Hub Two
HTH
Edit: there is no setting on the Hub to change the update time or disable them.
mattio
Thanks Dan, it must be something else that's shutting it down then!
When you say shutting it down, are you talking about the Hub having overnight disconnects or Hub restarts?
If it's the Hub hopefully the event log will tell the story,.
From the home page navigate Advanced Settings >Technical log >Event log. If you click on export it creates a file.
Attach it to a post and I'll take a look to see if it's something obvious
mattio
Overnight there was this event
01:36:10, 12 Jul. DSL Link Down: duration was 497450 seconds
DSL link is between your Hub and the Green cabinet. It could just be a result of the DLM (Dynamic Line Management) re-sync of your connection as these usually occur overnight, these are automatically performed by the DLM system and are not always predictable.
Your current line sync is
01:36:48, 12 Jul. DSL Link Up: Down Rate=76056kbps, Up Rate=18756kbps; SNR Margin Down=3.4dB, Up=5.9dB
The previous DSL Link down messages were
07:24:50, 06 Jul. DSL Link Down: duration was 1160 seconds
07:04:24, 06 Jul. DSL Link Down: duration was 20933 seconds
01:15:00, 06 Jul. DSL Link Down: duration was 367606 seconds
Currently not a major issue, however if they start more often it would be worth further investigation.
