Firmware update for Hub one
M3SNU-Steve
Hello I am currently on firmware version.263 updated unknown for hub one router, is this the current version?
if there a new firmware available is it possible for someone to push it out to my router?  I hope you can can help thank you for your time.
my router serial no is  +081441+NQ40621720
Stephen Hayes
4 REPLIES 4
Fixes: 1,600
Re: Firmware update for Hub one
Hi @M3SNU-Steve
If you're on 4.7.5.1.83.8.263 this is currently the latest version
M3SNU-Steve
Thanks very much for your response, it looks like I’m on the latest version.  Thanks for your help.  Have a nice day.
Fixes: 1,600
No problem Steve, let us know if there's anything else you'd need help with
RealAleMadrid
Aspiring Hero
Fixes: 59
@M3SNU-Steve  The version .263 is the latest fully released version, but there are other test releases pushed out by @bobpullen who is working on the fixes for the multitude of problems with the Hub1 particularly with regard to wf-fi dropping out and not reconnecting to devices.
Try posting on the thread below and Bob may send you a later firmware, not sure if it has fixed all the bugs yet. I don't use ISP provided routers, they are usually cheap and not very good.🙄
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1812272#M26578
