Firmware broke my HH6 wifi
- My Router
- Firmware broke my HH6 wifi
03-04-2019 8:00 PM
My wifi completely disappeared yesterday and after spending several hours last night fiddling with the HH6 realised that this coincided with a firmware update. When I say disappeared, I actually mean disappeared. The hub's homepage reports the wifi status as "off", but the hub's wireless page says that it is "on". I've factory reset etc etc etc but there is no wifi network broadcast by the router.
I communicated with PlusNet support this evening who's only response was to try to sell me a new contract that would come with a new router!!! I explained that I would be very happy to talk about renewing, but this wasn't the time because I needed to get my wifi back on line now. The support guy didn't seem to understand that whilst he was trying to sell me stuff and was not fixing my problem I was unlikely to buy anything. I started out with Force 9 around the turn of the century and this is the only bad experience I have, but is going to send me looking for another provider.
Does anyone have a possible fix for this firmware issue?
Re: Firmware broke my HH6 wifi
03-04-2019 8:05 PM
This topic has been moved from ADSL Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
03-04-2019 8:19 PM
You may not like the reply when they do. I think it will be along the lines of "we don't support 3rd party routers". Whilst BT is the parent company of PN, they are 2 separate entities and Home hubs will be treated the same as Sky, Talk Talk, et al.
03-04-2019 8:19 PM
I take it you have a BT Home Hub (not a Plusnet router).
It doesn't seem very likely that some BT pushed firmware broke your hardware however it's not impossible.
If it were a widespread issue I would expect it to make news coverage as many people have BT service and their router.
Do you have a Plusnet supplied router to try ?
Assuming you want a BT HH6 buying another (via an auction site) seems the way to go,
03-04-2019 8:33 PM
new from an auction site and it's WiFi totally failed following a firmware update pushed by PlusNet. They acknowledged it by saying they could push another but it may take 24 hours. I'd have been happy with that and an apology, but they just kept saying I needed a new contract and they would send a new router. I only recently bought this router because theirs was failing and there was nothing wrong with it until their update.
03-04-2019 8:38 PM
03-04-2019 8:39 PM
As has already been said, you are not going to get support for a router that is not theirs, they don't control it, and unlikely to have knowledge of it.
Why don't you ask on the BT Form, you don't have to say you are on PN, but let them know what firmware you have.
Have you tried turning the WiFi off, then back on? In the advanced menu I think.
03-04-2019 8:40 PM
Well John,
If Plusnet really pushed firmware to the BT HH6 and broke it, that is an interesting development and likely to result in a good few complaints.
I've a feeling that the person you spoke to had some confusion between firmware pushed to Plusnet's own routers and your HH6.
Hopefully you will get a response from a Plusnet staff member shortly on this thread.
03-04-2019 8:45 PM
03-04-2019 8:48 PM
PN don't have a firmware for the BT HH6.
03-04-2019 8:50 PM
03-04-2019 11:49 PM
They will have gone away to request that the firmware be pushed out to a Plusnet router that is connected to your account. Having determined that you may need a new router, and that you aren't eligible for a free one from Plusnet, there are only really four options:
- Sell you a router (around £50 if I remember correctly)
- Tell you to go and buy your own router
- Suggest that you recontract, part of which would mean that you are eligible for a free router
- Tell you there is nothing they can do for you
03-04-2019 11:54 PM
It will.
The home (status) page is for of BT Wi-fi (formerly known as BT Fon), though mines worded 'Not active' and not 'off'.
You're using a Hub6 on a Plusnet connection, thus BT Wi-Fi can't be active.
That's something completely different. If you're using a windows based PC/Laptop, try connecting via ethernet, check for windows updates, probably apply at least one, reboot (as possibly instructed) and then you might find the wifi broadcasts start to show.
HTH
04-04-2019 1:11 AM
@markhawkin wrote:
Well John,
We have zero control over the hardware management platform used by BT, and as such there is no way we can push a firmware update to a BT-provided Hub.
The firmware images are signed anyway - a BT Hub wouldn't accept a Plusnet signed image even if it was possible to push an update.
04-04-2019 9:32 AM
Hopefully you are now convinced that this problem is not of Plusnet's making.
After the factory reset did you set it up from scratch again? If so can you connect tp Plusnet using an Ethernet cable?
If yes to these it might help if you could post screenshots of the relavent smarthub pages here so that we could see if we can spot anything out of place in the settings. It could of course be that the firmware update has caused this issue or that it is an unfortunate coincidence.
