Firmware Upgrade please? Slow upload speeds!
cookalarcha
Hey my download speed on fibre maxes out about about 25mbps and my upload at most reaches 2mbps at most.
I've read firmware updates could help with the issue?
Currently on Software version 4.7.5.1.83.8.237.2.2
Is there anything else I can do to increase speeds? Would the priority add-on change anything?
I've tried to stream on twitch but the upload speed is crippling the quality.
8 REPLIES 8
Fixes: 1,483
Re: Firmware Upgrade please? Slow upload speeds!
what does the checker say you should be achieving? https://www.dslchecker.bt.com/
Fixes: 418
@cookalarcha
Be careful what you ask for, especially if you have any Amazon devices. See https://community.plus.net/t5/My-Router/SSID-disappearing/m-p/1602456#M9353
HarryB
Fixes: 256
Hi @cookalarcha,
Looking at the estimates for your line, I'm afraid this may simply be down to the capabilities of the line, as the figures you've mentioned are within the estimates we'd expect your connection to perform within:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 29.8 21.8 3.2 1.6 19.1 Available Available --
EDIT: Added DSLChecker estimates.
 Harry Beesley
cookalarcha
Does not look good?
cookalarcha
Aww man. Does not help I am like 1-2km away from the nearest box too. But basically nothing can be done to increase it? Even if I could get a consistent 2+ it would be better.
Thanks anyways guys
HarryB
Fixes: 256
Unfortunately we wouldn't be able to guarantee an increase in speeds as the connection is performing within the estimates. Apologies for any inconvenience this causes.
 Harry Beesley
bobpullen
Fixes: 316
@cookalarcha, I've upgraded your router to the latest available firmware build, however as @HarryB says, I doubt it's going to help as your line is only synchronising at ~2.5mbps up :(:
cookalarcha
Thanks, it wont change anything I am going to have to look into a 4G dongle or something to supplement myself if I decide to stream to increase the quality. 4G get 20mbps Download and 7-9mps upload no problem.
 It's frustrating that this is faster than an actual fibre broadband.
