Firmware Update Required?
- My Router
- Firmware Update Required?
14-07-2020 4:08 PM
Hi
My Dell Laptop keeps disconnecting (and also kicking other devices from my system). Dell tell me that I likely require a Firmware update. Is it possible to check/push this please?
My details:
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 27/03/19
Serial: +081441+NQ71702652
MAC F46BEF468048
Is there any other detail I need to provide?
Thanks in advance!
Re: Firmware Update Required?
16-07-2020 3:09 PM
Hi @jjandellis, you're already on the latest stable firmware update available. Given your description of the issue you might find this thread relevant: https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363
