Firewall fighting with UPnP.....
mw0dcm
Hey all,
Thought I'd try once more to see if anyone else has this issue?
I run a Plex Media Server, internally it works a charm, but when both UPnP and firewall are both on Plex remote falls over and isn't available via the WAN, but as soon as I switch the Hub firewall off, Plex remote works. I've noticed that my Xbox also has an issue with this, and that device moans that it cannot get DNS access with both switched on.
The Technical Log says unknown d for the firmware, and this is a brand new router that was sent out to attempt to fix the same issue as the router that was unplugged_.
So my question is has anyone else got it seen this issue? I'm currently rubbing the router without firewall on
Many thanks in advance....
Dave
Tags (4)
