Fibre router making a hissing noise
dan17
The router we got sent makes a hissing noise when devices on 5GHz are using it. The CS suggests to turn off the 5 band but that’s no good as WiFi speed cuts down from 58 mbps to about 30. Is there anything that can be done?
3 REPLIES 3
Fixes: 418
Re: Fibre router making a hissing noise
@dan17
Go onto an auction site such as EBay and spend very little money on a BT Smarthub 6. Setting instructions ae here:  https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
RandallFlagg
Fixes: 75
Hi @dan17
Unfortunately, our supplier has advised that the hissing sound is within tolerance for the design of the Hub One and therefore there's nothing that we can do in terms of negating this if disabling/splitting out the 5hz frequency doesn't help.
My apologies that I couldn't respond with better news.
Best wishes
Dave
dan17
Hi Dave,
That’s ok, thank you for the info. I will try the BT smart hub 6 and see what happens.
