Fibre broadband keeps dropping out
- My Router
- Fibre broadband keeps dropping out
3 weeks ago
Re: Fibre broadband keeps dropping out
2 weeks ago
The most likely cause is phone wiring inside your home.
It is mildly painful to do but Plusnet have a "broadband troubleshooter"
https://www.plus.net/help/broadband/connection-troubleshooting/
The end of this process is to try the router connected directly plugged into the "test socket" that you (probably) have in your BT socket.
2 weeks ago
Hi Leigh,
I appreciate your query and apologise for any issues with your connection.
I've run a full diagnostic test on your line and there does not appear to be any issues with your connection or speed. The orange 'b' can suggest an issue with authentication if accompanied by the router lights also going orange.
Please can you check the authentication details entered into the router and make sure they match your Member Centre information. Please also connect to your test socket as advised.
Thanks - LF
- My Router
