Faulty Plusnet Router
- My Router
- Faulty Plusnet Router
21-10-2019 2:58 PM
Hello,
The wired Ethernet ports on my broadband router have stopped working for some reason. I've not changed anything or moved the router, and I know the network streamer that plugs into it works because I've tested on the broadband router of a family member (different house). I've also tried plugging a patch cable in to my laptop; nothing lights up on the port and Windows shows the cable as disconnected. It was working fine until Friday.
Is there anything else I can try?
Thanks,
Re: Faulty Plusnet Router
21-10-2019 3:18 PM
Are you saying that you can get wireless internet access but all four Ethernet ports have failed?
21-10-2019 3:44 PM
Yes.
21-10-2019 5:45 PM - edited 21-10-2019 5:45 PM
Contacted support who reset the router, but the problem is still there. Faulty router suspected. The router is out of warranty now (over 12 months) :-(.
Will have to wait for a new contract (with new router) or I'll have to buy another one.
Thanks for the replies.
21-10-2019 9:35 PM
You can get a BT Smarthub 6 for less than £20 from EBay. These are better than Plusnet offerings. Setting instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
21-10-2019 9:36 PM
I'm sorry that we couldn't get this sorted for you.
Just to let you know - you can recontract within the last three months of your current contract - just give our Customer Options Team a call on 0800 328 4624.
Kind regards,
Dave
