Faulty Lan ports on Plusnet hub
hercs
Hi
Seems to have a fault on one of my LAN ports on my Plus one hub router. No matter what lan cable I plug in it has no connections.
I have already changed to new Lan cables, all other 3 are fine apart from one.
My current  Software version 4.7.5.1.83.8.237.2.2 ,, which was Last updated 30/08/17 ,, I believe a newer version 2018 is out,, will a new version fixed my issue Or can I get a replacement  hub.
I need to use all lan ports of my routers, if possible.
thanks
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 29
Re: Faulty Lan ports on Plusnet hub
Fixes: 414
It sounds like a faulty router. If it's less than 12 months old Plusnet will replace it under warranty. If it's older then you may need to take out a new contract if you want a freebie.
Strat
Fixes: 565
Moderator's note by Dick (Strat): Topic moved to a more appropriate board.
bobpullen
Fixes: 315
Have you tried factory resetting the device using the pinhole at the rear?
