Fast Ethernet Speed But Slow WiFi Speed
- My Router
- Fast Ethernet Speed But Slow WiFi Speed
15-02-2020 11:02 PM
Only been with Plusnet 2/3 weeks, but tonight our WiFi speed has dropped massively to 20/25 MBPS based on speedtest.net
I've connected it to ethernet and the speed is fine through cable.
Any idea on a fix or is this just a thing that can happen from time to time on busy periods and to try again tomorrow etc to see what the speeds are? Just think it's considerably low for WiFi
Re: Fast Ethernet Speed But Slow WiFi Speed
15-02-2020 11:18 PM
Seems a restart of the router has fixed it currenty getting the WiFi speeds expected, very odd! Is it normal that a restart router would fix the issue then?
15-02-2020 11:40 PM
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
19-02-2020 11:23 AM
19-02-2020 11:24 AM
- My Router
