FTP Uploads causing Plusnet Hub One to crash / disconnect
RoryG
Re: FTP Uploads causing Plusnet Hub One to crash / disconnect
Hi Bob,
Not really, it seemed OK for a bit, however it is restarting regularly and not always when I am doing FTP uploads. Also, when it does reboot it can take an age to sync again, the old router used to restart and sync in about five minutes.
Here's the boot log for August / September:
21:32:32, 07 Sep. ( 28.800000) System up, firmware version: 4.7.5.1.83.8.237.2.2
21:32:16, 07 Sep. ( 13.440000) System start
21:32:16, 07 Sep. ( 13.440000) Boot reason: watchdog reset (cause: 0x2)
08:17:34, 30 Aug. ( 27.880000) System up, firmware version: 4.7.5.1.83.8.237.2.2
08:17:20, 30 Aug. ( 13.690000) System start
08:17:20, 30 Aug. ( 13.690000) Boot reason: watchdog reset (cause: 0x2)
07:07:36, 28 Aug. ( 26.680000) System up, firmware version: 4.7.5.1.83.8.237.2.2
07:07:22, 28 Aug. ( 13.470000) System start
07:07:22, 28 Aug. ( 13.470000) Boot reason: watchdog reset (cause: 0x2)
13:35:18, 23 Aug. ( 29.360000) System up, firmware version: 4.7.5.1.83.8.237.2.2
13:35:02, 23 Aug. ( 13.230000) System start
13:35:02, 23 Aug. ( 13.230000) Boot reason: watchdog reset (cause: 0x2)
03:17:38, 21 Aug. ( 27.660000) System up, firmware version: 4.7.5.1.83.8.237.2.2
03:17:23, 21 Aug. ( 13.320000) System start
03:17:23, 21 Aug. ( 13.320000) Boot reason: watchdog reset (cause: 0x2)
15:37:37, 16 Aug. ( 28.450000) System up, firmware version: 4.7.5.1.83.8.237.2.2
15:37:22, 16 Aug. ( 13.640000) System start
15:37:22, 16 Aug. ( 13.640000) Boot reason: watchdog reset (cause: 0x2)
14:42:37, 15 Aug. ( 28.910000) System up, firmware version: 4.7.5.1.83.8.237.2.2
14:42:22, 15 Aug. ( 13.720000) System start
14:42:22, 15 Aug. ( 13.720000) Boot reason: watchdog reset (cause: 0x2)
12:17:34, 15 Aug. ( 28.400000) System up, firmware version: 4.7.5.1.83.8.237.2.2
12:17:18, 15 Aug. ( 13.150000) System start
12:17:18, 15 Aug. ( 13.150000) Boot reason: watchdog reset (cause: 0x2)
04:52:37, 13 Aug. ( 25.490000) System up, firmware version: 4.7.5.1.83.8.237.2.2
04:52:25, 13 Aug. ( 13.490000) System start
04:52:25, 13 Aug. ( 13.490000) Boot reason: watchdog reset (cause: 0x2)
07:57:34, 11 Aug. ( 27.630000) System up, firmware version: 4.7.5.1.83.8.237.2.2
07:57:19, 11 Aug. ( 13.150000) System start
07:57:19, 11 Aug. ( 13.150000) Boot reason: watchdog reset (cause: 0x2)
19:12:41, 05 Aug. ( 27.700000) System up, firmware version: 4.7.5.1.83.8.237.2.2
19:12:26, 05 Aug. ( 13.120000) System start
19:12:26, 05 Aug. ( 13.120000) Boot reason: watchdog reset (cause: 0x2)
Fixes: 585
@RoryG that's running pretty old firmware!
@bobpullen tagged for visibility
RoryG
I thought it must be, when I tried to copy the settings from my old router it said "incompatible file" and would not import. I thought firmware updates were automatic over the wire? That's the firmware that was on it when Bob sent it up.
bobpullen
Fixes: 331
I don't understand how a hub running 4.7.5.1.83.8.237.2.2 can even have left the warehouse. Are you 100% sure that's the newly dispatched one?
RoryG
Hi Bob, yes that's the one I received from you. It seems to be restarting on an almost daily basis now:
18:07:36, 09 Sep. ( 28.080000) System up, firmware version: 4.7.5.1.83.8.237.2.2
18:07:21, 09 Sep. ( 13.690000) System start
18:07:21, 09 Sep. ( 13.690000) Boot reason: watchdog reset (cause: 0x2)
18:32:35, 08 Sep. ( 28.500000) System up, firmware version: 4.7.5.1.83.8.237.2.2
18:32:19, 08 Sep. ( 13.230000) System start
18:32:19, 08 Sep. ( 13.230000) Boot reason: watchdog reset (cause: 0x2)
10:32:38, 08 Sep. ( 28.090000) System up, firmware version: 4.7.5.1.83.8.237.2.2
10:32:23, 08 Sep. ( 13.410000) System start
10:32:23, 08 Sep. ( 13.410000) Boot reason: watchdog reset (cause: 0x2)
