Extension cabling socket -> router
- My Router
- Re: Extension cabling socket -> router
29-10-2020 7:28 PM
Need to move router (Hub One), adding a 15M extension cable between socket and router
is it better to do
'phone socket -> adsl filter -> adsl extension cable -> router
OR
'phone socket -> 'phone extension cable -> adsl filter -> router
Or doesn't it make any significant difference?
29-10-2020 9:13 PM
You can get filtered face plates which remove the need for the adsl filter. I used the following back in the day but there are others including one from BT.
https://www.adslnation.com/products/xtf.php
Use a good quality extension.
30-10-2020 11:15 AM
Best solution is to leave the hub by the BT Master scket and run an Ethernet cable (and a mains extension if necessary) to where you need your data port.
Else suck it and see which works best.
- My Router
