Extend Range On Plusnet Hub One With Addition Router Help Please
- My Router
- Extend Range On Plusnet Hub One With Addition Rout...
on
01-11-2016
9:00 PM
- last edited on
01-11-2016
9:04 PM
by
Mav
Hello, I am trying to find some assistance on how to connect an additional old router to the hub one to extend my range. I have a wired connection between the two locations but need some advice on how to achieve this. hop someone can give assistance, thank you.
Moderator's note by Mike (Mav): All caps title edited as per Forum rules.
Re: Extend Range On Plusnet Hub One With Addition Router Help Please
02-11-2016 11:45 AM
Hi Keggers,
In a nutshell this usually means turning off DHCP on the router you want to use as a wireless access point. How you do this depends on what router you're using.
Here's a post about using one of our older models of router to do this which might point you in the right direction:
- My Router
