Example Internet Config for a Nighthawk AC1900 D7000v2 modem please -- I can't get mine to work
- My Router
- Example Internet Config for a Nighthawk AC1900 D70...
27-04-2020 6:21 PM
Can someone please put up screenshots of the configuration needed to get a Nighthawk AC1900 D7000v2 working with PlusNet's VDSL service?
I have got as far as the screen shot below - and still can't get it to work
I have the modem work on my previous ADSL configuration - but the VDSL service is switched on today so I should be able to use it.
Of particular concern to me are the following seetings which I cannot get clear info on from the PlusNet info.
1) Multiplexing method - still "VC-BASED" ?
2) Are VPI and VCI still relevent ?
3) Are my VLANID settings correct? PlusNet speaks of (802.1q) and (802.1p) while Nighhowk has just VANLID and priority - are these the same?
4) Should log in be the same as with ADSL. For ADSL it was xxxxx@f9.co.uk should it ne the same or xxxxx@plusdsl.net
5) Should Connection Mode (after password) be blank ?
Many thanks.
Re: Example Internet Config for a Nighthawk AC1900 D7000v2 modem please -- I can't get mine to work
27-04-2020 6:29 PM
Moderators Note
This topic has been moved from Fibre to My Router
27-04-2020 6:36 PM
are you sure it got switched on today ? Try putting the adsl parameters back. Your switch over may have been delayed
1) Multiplexing method - still "VC-BASED" ? not used for vdsl
2) Are VPI and VCI still relevent ? no
3) Are my VLANID settings correct? yes PlusNet speaks of (802.1q) and (802.1p) while Nighhowk has just VANLID and priority - are these the same?
4) Should log in be the same as with ADSL. For ADSL it was xxxxx@f9.co.uk should it ne the same or xxxxx@plusdsl.net same
5) Should Connection Mode (after password) be blank ? that's service name , can be blank. Connection should be always on
28-04-2020 10:43 AM
From my much older D6400 :
- My Router
