Enabling IPv6 on hub two
grump
Hi guys I'm new here, just installed a new Hub Two. It has IPv6 disabled but I've a device which is trying to connect via IPv6 can I just enable IPv6 or will that cause me other issues. All my other devices seem happy with IPv4. Thoughts would be appreciated.
5 REPLIES 5
Marsh
Fixes: 42
Re: Enabling IPv6 on hub two
Heya @grump
At the moment, you are not able to enable IPv6 as of right now. Currently, IPv6 is in the trial phase, and it's not possible to enable it unless you are a part of the trial
Josh
grump
Okay understood I need to ensure device connects IPv4. Thank you
Fixes: 392
@grump What is this device 'trying to connect via IPv6'?
grump
LuxPower Inverter, Solar Panels, Battery etc.
Fixes: 392
OK. Sorry, my post crossed with @Marsh 's and your reply.
