Edgerouter POE unable to connect to internet
- My Router
- Re: Edgerouter POE unable to connect to internet
10-01-2017 9:00 PM
I'm new to the forum, and to the world of routers.
I've tried to configure thig futer, but have no internet connection. I set router up using the WAN+2LAN2 wizard.
Looking at other posts, its notable that my pppoE IP address is 172.22.37.29/32. This suggests it is in the private range, and implies a username or password error, however both appear to be correct.
Downloading the config file, and comparing with others posted, its noticeable that section showing port forwarding, hairpin enable, wan-interface pppoe is missing, but I may just be misunderstanding the example config file.
The log file shows
Jan 10 20:53:02 | ubnt ntpd_intres[25999]: host name not found: 3.ubnt.pool.ntp.org |
Jan 10 20:53:02 | ubnt ntpd_intres[25999]: host name not found: 2.ubnt.pool.ntp.org |
Jan 10 20:53:02 | ubnt ntpd_intres[25999]: host name not found: 1.ubnt.pool.ntp.org |
Jan 10 20:53:02 | ubnt ntpd_intres[25999]: host name not found: 0.ubnt.pool.ntp.org |
Jan 10 20:52:43 | ubnt pppd[19627]: Timeout waiting for PADO packets |
Jan 10 20:51:28 | ubnt pppd[19627]: Timeout waiting for PADO packets |
I am not seeing any outbound or inbound traffic
All help gratefully received!
11-01-2017 10:39 AM
Can you post your config?
Here is mine for PPPOE authentication:
ethernet eth0 {
description "Internet (PPPoE)"
duplex auto
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
mtu 1492
name-server auto
password ****************
user-id xxx@plusdsl.net
11-01-2017 11:11 AM
What actually are you trying to do and what are you connecting it to as this unit is neither an ADSL or FTTC capable router
11-01-2017 11:27 AM - edited 11-01-2017 11:31 AM
These are enterprise routers, it will be connected to a DSL model (Hopefully!)
11-01-2017 12:29 PM
The Router is connected to a BT Openreach fibre broadband modem.
11-01-2017 1:11 PM
what format are you using for the username as it should be username@plusdsl.net with your normal account password
11-01-2017 1:39 PM
Good Afternoon,
Can you PM me your Plusnet username please. If you're getting a 172.x.x.x IP address, this generally infers that the DSLAM has placed you in the walled garden due to repeated failed connection attempts. With your username, I can access your account and check that for you.
11-01-2017 4:57 PM
My config;
ubnt@ubnt:~$ cat /config/config.boot
firewall {
all-ping enable
broadcast-ping disable
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name WAN_IN {
default-action drop
description "WAN to internal"
rule 10 {
action accept
description "Allow established/related"
state {
established enable
related enable
rule 20 {
action drop
description "Drop invalid state"
state {
invalid enable
name WAN_LOCAL {
default-action drop
description "WAN to router"
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
options {
mss-clamp {
mss 1412
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
bridge br0 {
address 192.168.1.1/24
aging 300
bridged-conntrack disable
description "Local Bridge"
hello-time 2
max-age 20
priority 32768
promiscuous enable
stp false
ethernet eth0 {
address dhcp
duplex auto
poe {
output off
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
mtu 1492
name-server auto
password NNNN
user-id NNNN
speed auto
ethernet eth1 {
bridge-group {
bridge br0
duplex auto
poe {
output off
speed auto
ethernet eth2 {
duplex auto
poe {
output off
speed auto
ethernet eth3 {
duplex auto
poe {
output off
speed auto
ethernet eth4 {
duplex auto
poe {
output off
speed auto
loopback lo {
switch switch0 {
bridge-group {
bridge br0
mtu 1500
switch-port {
interface eth2 {
interface eth3 {
interface eth4 {
vlan-aware disable
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name LAN_BR {
authoritative enable
subnet 192.168.1.0/24 {
default-router 192.168.1.1
dns-server 192.168.1.1
dns-server 208.67.222.222
lease 86400
start 192.168.1.38 {
stop 192.168.1.243
use-dnsmasq disable
dns {
forwarding {
cache-size 150
listen-on br0
gui {
http-port 80
https-port 443
older-ciphers enable
nat {
rule 5010 {
description "masquerade for WAN"
outbound-interface pppoe0
type masquerade
ssh {
port 22
protocol-version v2
system {
host-name ubnt
login {
user NNNN {
authentication {
encrypted-password NNNN
level admin
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
offload {
hwnat disable
ipv4 {
forwarding enable
pppoe enable
11-01-2017 4:59 PM
Ah,
I have username@plusnetdsl.net.
I'll try that
11-01-2017 5:21 PM
Progress. Thank-you. Changing the username gave me a more valid IP address for pppoE:
81.174.146.187/32
Which is consistent with the WAN IP address
But still no internet. Error message is DNS_PROBE_FINISHED_NO_INTERNET
Log is;;
Jan 11 17:17:36 | ubnt pppd[20611]: Timeout waiting for PADO packets |
Jan 11 17:17:06 | ubnt ntpd_intres[21172]: host name not found: 3.ubnt.pool.ntp.org |
Jan 11 17:17:06 | ubnt ntpd_intres[21172]: host name not found: 2.ubnt.pool.ntp.org |
Jan 11 17:17:06 | ubnt ntpd_intres[21172]: host name not found: 1.ubnt.pool.ntp.org |
Jan 11 17:17:06 | ubnt ntpd_intres[21172]: host name not found: 0.ubnt.pool.ntp.org |
11-01-2017 5:38 PM
If you've got a valid WAN IP now then that's progress. Looks like your config is somehow preventing access.
Try the following:-
configure
delete interfaces
Paste the following commands, ensure to replace your user/pass in lines 8 and 9.
set interfaces ethernet eth0 description 'Internet (PPPoE)'
set interfaces ethernet eth0 duplex auto
set interfaces ethernet eth0 pppoe 0 default-route auto
set interfaces ethernet eth0 pppoe 0 firewall in name WAN_IN
set interfaces ethernet eth0 pppoe 0 firewall local name WAN_LOCAL
set interfaces ethernet eth0 pppoe 0 mtu 1492
set interfaces ethernet eth0 pppoe 0 name-server auto
set interfaces ethernet eth0 pppoe 0 password xxxxxxxx
set interfaces ethernet eth0 pppoe 0 user-id nnnnnnnn
set interfaces ethernet eth0 speed auto
set interfaces ethernet eth1 description Local
set interfaces ethernet eth1 duplex auto
set interfaces ethernet eth1 speed auto
set interfaces ethernet eth2 description Local
set interfaces ethernet eth2 duplex auto
set interfaces ethernet eth2 speed auto
set interfaces ethernet eth3 description Local
set interfaces ethernet eth3 duplex auto
set interfaces ethernet eth3 speed auto
set interfaces ethernet eth4 description Local
set interfaces ethernet eth4 duplex auto
set interfaces ethernet eth4 poe output pthru
set interfaces ethernet eth4 speed auto
set interfaces loopback lo
set interfaces switch switch0 address 192.168.4.1/24
set interfaces switch switch0 description Local
set interfaces switch switch0 mtu 1500
set interfaces switch switch0 switch-port interface eth1
set interfaces switch switch0 switch-port interface eth2
set interfaces switch switch0 switch-port interface eth3
set interfaces switch switch0 switch-port interface eth4
set interfaces switch switch0 switch-port vlan-aware disable
commit
Then try pinging google from the router
11-01-2017 8:46 PM
Just to check before I do this - (plus I will have to learn how to download, modify and reload config file).
I have reviewed the code you suggested in the config tree.
I have a bridge br0, with address 192.168.1.1/24.
Your code doesn't appear to have a bridge - I am assuming this is replaced by the switch switch0.. I assume where your code has switch IP address 192.168.4.1/24 this reflects your individual needs, and I would need 192.168.1.1/24 - or am I incorrect? My bridge br0 has MTU 1500 and description local - as the proposed switch, but does not have any of the interfaces.
Is there a reason for doing a switch rather than a bridge? Would my bridge work if I added interfaces to it - assuming this is a sensible question?
All my other config code looks the same in the config tree
My brid
11-01-2017 8:51 PM
One other point I just noticed - my eth0 address is shown as DHCP, whereas the proposed code has no address shown - is this significant?
11-01-2017 8:54 PM
You are correct.
However my method was to get a simple, working configuration up and running (the one I posted is a basic PPPOE WAN on eth0 with eth1/eth2/eth3/eth0 configured as standard switching (switch0)).
Once it is working you can add your custom configuration to suit your needs, i.e. bridging, etc.
11-01-2017 8:59 PM
My eth0 doesn't show as address DHCP:
interfaces {
ethernet eth0 {
duplex auto
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
mtu 1492
name-server auto
user-id xxxxxx@plusdsl.net
speed auto
ethernet eth1 {
description Local
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
poe {
output pthru
speed auto
loopback lo {
switch switch0 {
description Local
mtu 1500
switch-port {
interface eth1 {
interface eth2 {
interface eth3 {
interface eth4 {
- My Router
