EE Smart hub
FIXEDTopic Options
- My Router
- EE Smart hub
02-09-2023 10:09 AM
Hello All,
I've just signed up to Plusnet FTTP 500 coming from EE FTTP 900. Would I be right in thinking I can use the EE Smart hub on Plusnet and if this is the case can I continue to use the smart WiFi discs I already have set-up? (Basically I'm just changing providers and hopefully just changing username and password)
Thank you
J
Thank you
J
Fixed! Go to the fix.
Message 1 of 3
(1,730 Views)
2 REPLIES 2
02-09-2023 12:32 PM
Do you really mean the EE Smart Hub, or do you mean the Smart Router?
The former is limited to 30Mbps upload so would have limited your speeds.
Otherwise, yes, just change username and password to work on PN.
Message 2 of 3
(1,707 Views)
Re: EE Smart hub
02-09-2023 12:34 PM
Yes my apologies the smart router. Thank you for the reply.
Kind regards
Kind regards
