EE Router Default Settings
MartinGoose
I am currently with Plusnet for fibre broadband and A&A for VOIP. A neighbour with Plusnet FTTC and PSTN line is facing a move to EE for broadband and VOIP. They have a significant amount of Ethernet cabling using the 192.168.1.1/24 subnet with static devices on fixed IPs and portable devices wireless using DHCP.
I am looking for information about the default settings for the currently supplied EE router to help plan ahead for their move. Any information/web links would be appreciated.
martin
2 REPLIES 2
Re: EE Router Default Settings
@MartinGoose
Like the plusnet Hub two the EE Hub/router IP Address is 192.168.1.254/24.
The EE hub GUI has many similarities to the Hub Two so hopefully you should be able to make the necessary changes if you have a one.
Edit: I would search the EE website for specific information.
Fixes: 388
I suggest you enquire on the EE forums - doubt that many people on here will be familiar with the EE router
@Dan_the_Van  beat me to it.
