Dreaded DECT Phone maybe....
Strat
Fixes: 563
I've been round at my daughter's this weekend and her whole family complained to me about their internet.
I did a speed test using my phone and got 2.69Mbps down and 0.26Mbps up. Usually it's considerably better as it's a good ADSL2+ line.
She doesn't like the router as it doesn't fit in with her décor sitting as it does on top of a shelving unit in the corner of the living room.
I glanced at the router lights, or I would have done if the router was there but it had been moved to the bottom shelf directly alongside the DECT house phone.
The router stats look ok
  Upstream    Downstream
Current Rate (Kbps) 1112 18420
Max Rate (Kbps) 1112 18208
SNR Margin (dB) 6.9 5.7
Line Attenuation (dB) 8 21.4
Errors (Pkts) 0 0
so I'm suspecting the DECT phone.
When I get the chance and my daughter is out of the room I'll relocate the router on top of the shelving unit.
Customer and Forum Moderator. Windows 10 Firefox 102.0 (64-bit (64-bit)
1 REPLY 1
Oldjim
Fixes: 63
Re: Dreaded DECT Phone maybe....
I will be interested in the result given that my router is right next to the DECT phone although it is fed by a shielded cable - the router that is
