Draytek Vigor 2862n works with Plusnet / Forec 9VDSL
- My Router
- Draytek Vigor 2862n works with Plusnet / Forec 9VD...
25-09-2019 5:31 PM
Any ideas?
Re: Draytek Vigor 2862n works with Plusnet / Forec 9VDSL
25-09-2019 5:39 PM
Moderators Note
This topic has been moved from Fibre to My Router
25-09-2019 8:53 PM
25-09-2019 10:09 PM
Yes, it does work although I have found the the VDSL and 5g WiFi connection very unreliable.
I would be interested in knowing how you get on.
26-09-2019 12:22 PM
@klemm those look like Adsl settings, I thought the OP was on an Fttc connection.
@adutton apart from entering your username & password , for fttc you need to ensure that the enable vlan tag insertion is enabled and set to 101
26-09-2019 12:36 PM
26-09-2019 1:37 PM - edited 26-09-2019 1:39 PM
@Anonymous you have a modem in front of your 2925 which is doing the VLAN tagging
I'm assuming the op wants to use the VDSL capabilities of the 2862 and therefore will need to enable the VLAN tagging
26-09-2019 2:17 PM
I do indeed, and I see it's default set to 101.
26-09-2019 3:16 PM
Hi
Thanks for replies
Seems to connect to the internet now but get theses messages
26-09-2019 4:34 PM
Sounds like you haven't got the username correct. It should be of the format username@plusdsl.net where username is the same as you use to logon to the member centre at www.plus.net
26-09-2019 5:36 PM
The Draytek 2862 will work, I'm connected using a 2860 typing this.
Try this guide from Draytek for BT with your Plusnet username and password instead of the BT one.
https://www.draytek.co.uk/support/guides/vigor-2860-vdsl-setup
You need (harmless) registration to see it.
26-09-2019 5:45 PM
These are my settings for VDSL.
The username and password are set on the page that looks like it is doing ADSL.
26-09-2019 5:49 PM
26-09-2019 5:57 PM
I did have a run of instability on the 2860 which went when I upgraded the firmware. I'm currently on 3.8.9.5_BT which seems OK and I think 3.8.9.3_BT was OK as well.
26-09-2019 6:07 PM - edited 26-09-2019 6:09 PM
From the title of this topic, it implies that @adutton is on an old Force9 account,
If that is the case the username format for Force9 was - username@f9.co.uk
@adutton login to the Plusnet Member Centre,
and then check your username format on this page - Connection Details - shown as "Login name"
- My Router
