Draytek Vigor 2850n
Lurch003
Draytek Vigor 2850n
Hi Guys
I must say, the plusnet experience so far has been awesome and problem free (take note Voda....fone). But I'm now trying to not break the fantastic service if I can help it.
I cannot seem to set up PIA (private internet access) on the hub so the IT guy at work has given me a Draytek Vigor 2850n that he says will, but might need settings to work with plusnet.
Did have a quick search on here but couldn't find anything- any ideas what settings might need completing and if I'm liable to have success or fail dismally?!!
5 REPLIES 5
Fixes: 1,483
Re: Draytek Vigor 2850n
not sure on the Vigor - but with regards to PIA that should work fine with your hub one, I use it.
What's the issue?
Fixes: 1,483
Here a previous post on a Vigor that might have a setting that needs tweaking
https://community.plus.net/t5/Fibre-Broadband/Draytek-Vigor-2860n-works-with-Plusnet-VDSL/td-p/13339...
Lurch003
What's the issue?
Oh really, I couldn't see anywhere to input the details. Could well be that I'm the problem then, will have another look when I get home.
I'm just looking to set it up on the hub rather than individually on all devices
Fixes: 1,483
ah ok, no you can't set it up to run on the router.
markhawkin
Fixes: 12
@Lurch003
while I've not set up a VPN like this on a Draytek 28xx router I think it should be possible as the Draytek supports encrypted tunnels between locations and that. is essentially what you want to do. There is lots of support on their UK website.
I think the Draytek isn't obvious at times but it is very capable,
