Draytek 2860 problems
weeally46
Hi, I'm having trouble with a draytek syncing at much lower speeds and using the mode G.dmt and adsl 2 instead of adsl 2+. Could some shed some light on this problem?
5 REPLIES 5
weeally46
Re: Draytek 2860 problems
An old BT router can sync at 21mbps on the same lne.
Fixes: 392
Dodgy Draytek?
Mav
Fixes: 518
Moderator's note(s):
Thread moved from ADSL Broadband to My Router.
Forum Moderator and Customer
Fixes: 587
https://www.draytek.com/support/knowledge-base/4798
markhawkin
Champion
Fixes: 22
I would definitely try the current firmware and BT modem code:
https://www.draytek.co.uk/support/downloads/vigor-2860
If that doesn't sort it, my occasional interactions with the UK Draytek support have been good.
I would ask them.
