Dont think my router should be making this noise
kingmuzzauk1
quick clip to show noise
https://youtu.be/5LHeN11fHmU
Maybe someone could send me a new one Thumbs_Up
I have only had it approx 4 weeks and its done it since i recieved it.
10 REPLIES 10
Mav
Fixes: 515
Re: Dont think my router should be making this noise
Moderator's note by Mike (Mav): This thread is now in the appropriate board.
Forum Moderator and Customer
Alex
Fixes: 13
Hub One - yes that's what we have and that is not right.
Surprised you managed to live with it for 4 weeks - I think 4 minutes maybe hours at most would test my patience.
kingmuzzauk1
I know it's one of them things I never got time to sort out..but have made time now as it's got so annoying and also could be dangerous if it started a fire!?
Fixes: 419
Let us be clear on one thing, it is not dangerous neither will it start a fire, it's just annoying. Also there seems to be more and more suffering, see here for the solution: https://community.plus.net/t5/My-Router/Noisy-Plusnet-One-Hub/m-p/1522799#M5922
Fixes: 1,600
Hi there. I'm sending a replacement router out to you.
Can you let us know how it goes when you receive it?
kingmuzzauk1
Will do thankyou
stevie5141
Hi, This is the EXACT same noise that my router is making also (see thread) https://community.plus.net/t5/Broadband/Plusnet-HubOne/td-p/1521428
Is it possible to get a replacement router too?
Sorry to hijack the thread.
RandallFlagg
Fixes: 75
Hi @stevie5141
I've responded on your original thread.
Thanks,
Dave
kingmuzzauk1
Thanks, new router has sorted it.
Fixes: 1,600
Glad to hear that!
Let us know if you need any further help.
