Does this router work with plusnet?
wolfheart
Once i get my broadband connection details I am thinking of getting this :- https://www.pcworld.co.uk/gbuk/computing-accessories/networking/network-routers-and-switches/routers...
I was wondering will I have any problems connecting to plusnet with it pleas?
Thank You
Wolfheart
10 REPLIES 10
Mustrum
Fixes: 75
Re: Does this router work with plusnet?
It's a cable router, so you would need a modem to work on PN.
wolfheart
Thank you, can you recommend a decent router with moden for plusnet for streaming and playing games please?
Thank You
Wolfheart
RichardB
Seasoned Champion
Fixes: 38
Hi wolfheart,
There  is a list of VDSL  routers on the Kitz forum.
http://forum.kitz.co.uk/index.php/topic,14436.0.html
General advice is not use a MediakTek chipset for modem function, they seem to have issues working with OpenReach's equipment. If you want to use a MediakTek device buy a separate modem.
The best chipsets for VDSL speed and stability are reputed to the broadcom chipset (BCM on the Kitz forum), followed by the Lantiq chipset.
Regards
Richard
wolfheart
Browni
Aspiring Hero
Fixes: 60
The chipset in the router doesn't matter, it's the chipset in the modem that can make a difference.
wolfheart
Browni
Aspiring Hero
Fixes: 60
Lantiq VRX200 series.
Linky.
wolfheart
Thank you, I  want a tri-band and one that is really good for gaming and streaming as we have many devices (ps4, xbox one, 3 Desk top Pc's and 5 laptops.
Wolfheart
Fixes: 1,481
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 401
It sounds to me that you would do better if you started by installing a Cat 5e Ethernet cable network to as many devices as possible before worrying about doing it all with a single top of the range router plus seperate modem. Ethernet cable will always be more reliable and should work out much cheaper even if you use the odd local wireless access point for wireless devices.
At the end of the day no matter what you spend nothing is going to improve the speed and latency of your connection from the BT fibre cabinet, which has to be shared by all these devices.
