Does this router work with plusnet?
- My Router
- Re: Does this router work with plusnet?
19-01-2019 11:14 PM
Once i get my broadband connection details I am thinking of getting this :- https://www.pcworld.co.uk/gbuk/computing-accessories/networking/network-routers-and-switches/routers...
I was wondering will I have any problems connecting to plusnet with it pleas?
Thank You
Wolfheart
19-01-2019 11:29 PM
It's a cable router, so you would need a modem to work on PN.
20-01-2019 12:27 AM
Thank you, can you recommend a decent router with moden for plusnet for streaming and playing games please?
Thank You
Wolfheart
20-01-2019 11:13 AM
Hi wolfheart,
There is a list of VDSL routers on the Kitz forum.
http://forum.kitz.co.uk/index.php/topic,14436.0.html
General advice is not use a MediakTek chipset for modem function, they seem to have issues working with OpenReach's equipment. If you want to use a MediakTek device buy a separate modem.
The best chipsets for VDSL speed and stability are reputed to the broadcom chipset (BCM on the Kitz forum), followed by the Lantiq chipset.
Regards
Richard
22-01-2019 8:29 PM
i am willing to buy a modem for the "
22-01-2019 9:03 PM
22-01-2019 9:32 PM
22-01-2019 10:06 PM
22-01-2019 11:02 PM
Thank you, I want a tri-band and one that is really good for gaming and streaming as we have many devices (ps4, xbox one, 3 Desk top Pc's and 5 laptops.
Wolfheart
23-01-2019 7:46 AM
Moderators Note
This topic has been moved from Fibre to My Router
23-01-2019 10:19 AM - edited 23-01-2019 11:19 AM
It sounds to me that you would do better if you started by installing a Cat 5e Ethernet cable network to as many devices as possible before worrying about doing it all with a single top of the range router plus seperate modem. Ethernet cable will always be more reliable and should work out much cheaper even if you use the odd local wireless access point for wireless devices.
At the end of the day no matter what you spend nothing is going to improve the speed and latency of your connection from the BT fibre cabinet, which has to be shared by all these devices.
- My Router
