Does my Hub 2 router have a username?
Ben1
I wonder if my Hub 2 has a username? I know that it has a password, but username?
Many thanks.
4 REPLIES 4
Fixes: 582
Re: Does my Hub 2 router have a username?
No it doesn't. When accessing the router gui, you can view some details with no password but the admin password is required for access to the advanced settings which allows changing settings.
Ben1
I have another Hub 2 question; does my Hub 2 have a default username and default password (i.e. the factory settings)?
Thanks.
As previously mentioned, the Hub Two does not have any username for any function just an admin password. The default password is found on the detachable card.
The Hub is best returned to factory settings using the pin hole on the back, push a paper clip or similar in the for around 20 seconds releasing when the light goes out.
HTH
Ben1
Great, thank you. I should have checked the rest of the thread, I realise!
